Sayfayý Yazdýr | Pencereyi Kapat
1/18 scale Tervamaki Engineering JT-9T au
Nereden Yazdýrýldýðý: ModelSitesi
Forum Adý: Tayyareler
Forum Tanýmlamasý: Uçabilen hersey hakkinda bilgi alisverisi alani
URL: www.modelsitesi.com/forum2/forum_posts.asp?TID=6567
Tarih: 31/08/2026 Saat 15:29
Konu: 1/18 scale Tervamaki Engineering JT-9T au
Mesajý Yazan: Nick_Karatzides
Mesaj Tarihi: 12/08/2009 Saat 15:46
1/18 scale Jukka Tervamäki Engineering JT-9T autogyro scratchbuild
Having tried my (suicidal) virgin 40 minutes flight experience with a friend's homemade autogyro during my summer holidays with him on flight controls and me on the passenger's backseat, I can surely say that you really feel like a bird, sensing even the slightest airwave or gravity accelerating change straight in your floating stomach. As soon as I safely stepped on solid ground again and returned back home in one piece, I felt the iresistable temptation to try a 1/18 scale autogyro scratchbuild. The following article is to describe step by step the 1/18 scale Jukka Tervamäki Engineering JT-9T autogyro, designed by Mr. Jukka Tervamäki and currently flying by ultralight aviators around the world keeping the http://www.madmaxmovies.com/cars/madmax2/Gyrocopter/ - Mad Max II GyroCaptain 's (aka Road Warrior) spirit alive!
In the photo below, Mr. Jukka Tervamäki, with his latest (at that time) creation of the JT-5, which was a predecessor of JT-9, which I'll try to represent in scale.
The basic JT-9 autogyro concept is about a tractor gyro design with good aesthetics and performance with fairly low power. A 1.7 m diameter 2-blades propeller is powered by HKS 700 or Hexadyne Aviation P60 diesel engines, both delivering about of 65 hp at 2400 rpm. The fuselage of the JT-9 is of normal steel tube construction covered with dacron fabric. On the other hand, the JT-9B model is equipped with an electric motor instead of a diesel engine, with only difference the 3-blades propeller and wider front cover to house the battery packs onto both sides of the fuselage. The model I'll try to build in 1/18 scale, is the two-seat trainer (as for the "T") JT-9T model, equiped with diesel engine & 2-blades propeller made by carbon fibers. Having the basic blueprint line diagrams in hand, it was easy to convert them into 1/18 scale with a photocopier and I began the scale model building, starting from zero using 0.25mm styrene card and plastic sprue. To make the construction look more interesting, I decide to build the model in a way that airframe should look like cutaway side opened and let cockpit detail be easily observed.
In the following pictures, the real (one-seat) Alex "GyroBeast2" Lameko's autogyro JT-9, during the successive stages of building.
Mesaj Tarihi: 12/08/2009 Saat 15:47
CHAPTER I - Basic airframe skeleton construction
Following the 1/18 scale printed diagrams and using just a sharp blade and CA super glue, it took about 60 minutes to build the basic airframe skeleton. The tiny gaps between the skeleton connections, were filled with Humbrol modeling putty, applied with an old brush. In order to make the putty liquid and let it spread naturally and fill the tiny gaps, I mixed it with laquer thinner. Because the laquer thinner is volatile, the liquid putty mixture took about 45 minutes to get fully dry and be safe to sand - carefully ofcourse. If you follow this method, be sure that you mix the laquer thinner and the modeling putty into a metal or glass plate / canister, because the most plastic materials cannot stand it and melt. For this reason, keep in mind to use just the essential laquer thinner quantity, in order to remain the mixture in liquid form, as it is presented at the following pictures.
About 45 minutes after lacquer thinner and Humbrol putty liquid mixture applied with brush on the skeleton to fill the tiny gaps between the connections, it looked to be fully dry and safe to sand it. As soon as that was done, the skeleton was hanged by a string and airbrushed with enamel mat white colour as a base coat. Cockpit floor, wheels etc made while waiting the putty to dry, were also spayed with base coat.
Mesaj Tarihi: 12/08/2009 Saat 15:50
CHAPTER II - Diesel engine building & painting
Setting as a task to build the model in a way that airframe look like cutaway side opened with cockpit and engine bay details visible, I should also leave the engine's cover opened. that offcourse means that a diesel engine building from scratch is something I couldn't easily avoid. Using plastic card, sprue, metal wire and unidentified parts found in the sparebox, here is my effort to build a realistic 1/18 scale engine.
After connecting with superglue the main elements, the electric cables and oil or diesel lines etc on engine's shape, I airbrushed it with enamel mat white color as a base coat, using high air pressure and spraying from distance to develop a pore surface and help silver & aluminum paint establish easier on plastic or metal engine's parts. As soon as the enamel mat white color seemed dry enough, a mixture of silver and aluminum paint sprayed on the engine and let about 24hrs to dry before trying to wash it with darker colors.
As I personally believe that following simple techniques and sometimes unconventional methods, result in superior effects, I usually do not use enamel or acrylic paint to wash, because I feel risky when applying the paint mixture and let it run. I prefer an easier technique that can be undone if the results are poor - that makes it the perfect technique. I use hard chalk pastels to wash (NOT oil pastels). The hard chalk pastels, look like a teacher would use on the blackboard in school. Do not use the soft oil pastels that artist use to draw on paper. The hard chalk pastels are easy to find in a variety of colours into your local art store or maybe http://www.walmart.com - Wal-Mart if in US or http://www.asda.co.uk - ASDA if in UK.
To do the wash, I use an X-acto knife, a small metal or plastic container, an old brush, dish washing soap and a bit of water. Begin by scraping some chalk powder from the side of the chalk pastel stick, carefully put this chalk powder into the small container and add a tiny amount of water and stir. It is important to add a tiny amount of water in order to make the mixture look like mud - not like soup! For this reason, I use a syringe to add just few drops on the hard chalk pastel powder and I stir using the old brush. Because the chalk powder doesn't mix well with the water, a drop of dish washing soap is needed to break the surface tension of the water and also acts as a "glue" to help the chalk powder stick to the model.
Once the chalk is fully dissolved into the water/soap mixture it is time to "paint" this mixture onto the model's engine. "Painting" the mixture is simple - just apply it anywhere it is needed to darken recessed detail. The mixture can be applied carelessly, because any mistakes can be completely removed and redone. Once the chalk wash dried, I rubbed off the high spots with a slightly damp dry (not wet) Q-Tip cotton swab (Kleenex papers can be also used) and I wiped the dark color from the areas should be light & shinny. The high spots were cleaned to the SNJ bare metal finish and the low spots were left black. I did the chalk wash on the engine in under 30 minutes which makes it a very quick and effective technique.
Some of the wash mixture is re-applied and the wash being wiped completely out of the narrow points. If you follow this method, it is adviced to not rinse out the wash container till you are finished this job. You will probably be touching up certain spots a few times, so it helps if you're not mixing up a new chalk mixture each time because you kept cleaning out your container of the chalk wash mixture. As soon as I paint the electric cables, the oil or diesel lines etc, I repeated the the wash process with lighter colors where needed. Using micro cotton batons found into cosmetic shop for less than 1£, I applied some red, orange, purple & brown chalk pastel powder on the engine's chrome excaust, to make it look overheated. I repeated the weathering process until it satisfied me and finally I sprayed a clear coat to seal the chalk powder on the engine.
Mesaj Tarihi: 12/08/2009 Saat 15:55
The scale model building, cost me almost nothing and took about 2 evenings work so far. I also send some pictures of my secret hideout / hobby room while scratchbuilding the 1/18 scale JT-9T autogyro model. Click on the first image to enlarge hi-res 180 degrees panoramic picture.
http://img43.imageshack.us/img43/1170/image0001v.jpg">
Mesajý Yazan: ice77
Mesaj Tarihi: 13/08/2009 Saat 03:08
he got a nice hello nick regular and F-16 model fresh in the meantime is how to get F-16 and the new construction phase and I look forward to pictures I wish you success...
Acemi Modelci
1977-Manisa
Mesajý Yazan: onge
Mesaj Tarihi: 13/08/2009 Saat 17:06
The engine looks great... Keep up the action...
Mesaj Tarihi: 31/08/2009 Saat 04:44
CHAPTER III - Instrument panel & cockpit construction
The original Tervamaki Engineering JT-9T autogyro instrument panel is not what you would call as "glass cockpit". Actually it does only have just the basic instruments in cockpit to provide the pilot with information about the flight situation, such as height, speed and attitude. Since the JT-8T autogyro is not designed to fly in conditions of poor visibility or night, the main information is available from visual reference outside the aircraft. Of course, many pilots who are lucky enough to own an autogyro, they might add more sophisticated equipment such as CFT screens, http://en.wikipedia.org/wiki/Horizontal_situation_indicator - HSI - Horizontal Situation Indicator to follow VOR signals, GPS screens, VHF/UHF radio, replace the heading indicator by a GPS-driven computer with wind and glide data etc. The basic instrument panel is consist by:
    [*]An http://en.wikipedia.org/wiki/Altimeter - altimeter indicator ,
    [*]an http://en.wikipedia.org/wiki/Attitude_indicator - ADI - AttituDe Indicator ,
    [*]an http://en.wikipedia.org/wiki/Airspeed_indicator - ASI - Air Speed Indicator ,
    [*]a http://en.wikipedia.org/wiki/Vertical_speed_indicator - VSI - Vertical Speed Indicator ,
    [*]a http://en.wikipedia.org/wiki/Fuel_gauge - fuel quantity indicator ,
    [*]an http://en.wikipedia.org/wiki/Tachometer - engine RPM tachometer ,
    [*]an analog clock and
    [*]a http://en.wikipedia.org/wiki/Compass - magnetic compass .
I started by cutting the main panel shape in plastic and drilled the gauges positions. Using the Corel Photo Paint, I created a coloured sketch of the instruments, copy & paste the image into a MS Word new file and print it on a simple A4 page. Meanwhile, I add some detail on the instrument panel, such as rivets made by streached sprue inserted in drilled out holes, knobs etc.
Mesajý Yazan: lterlemez
Mesaj Tarihi: 31/08/2009 Saat 19:49
Very nice work. I would like to see this work as a small booklet or as an article. Kolay Gelsin.
Adriano Guisebbe Lentini
Mesaj Tarihi: 05/09/2009 Saat 04:07
Using styrene plastic card, I cut the basic lines to form into the two simple seats. The dimensions are based on the basic 1/18 scale JT-9T two-seat trainer blueprint line diagram as seen http://s23.postimg.org/flnho7ckb/IMAGE_0004.jpg - HERE . On the real JT-9T autogyro, these simple seats are made of hard plastic, fiberglass or even wood sheet and buckram covered home made pillows are placed to provide comfort. These seats are fixed on metal rails, running across the cockpit floor connected with main skeleton, to ensure seat's secure installation.
For many years, I was used to form aircraft seat pillows with Milliput epoxy putty, which is popular among modelers and also useful in countless household & restoration applications. But, while I was in a supermarket last week, I found the following item and I thought that it could be nice to try it and start experiment with this material. It's an air-drying modeling clay ideal for scale modeling and shaping. According to the instructions, it can be easily formed into shape, become solid rock withing few hours, re-filled or sanded if neccessary and painted or lacquered. That sound quite good to me and similar to the well known Milliput epoxy putty, with the only difference that the 500g air-drying modeling clay pack cost only 1£, instead of 100g Milliput epoxy putty which cost 5£. That makes the new found air-drying modeling clay, about 25 times cheaper than Milliput epoxy putty and that's a good reason for me to give it a chance.
Picking a small quantity with a metal spatula and applying the air-drying modeling clay on the seats, it felt too soft and very easy to spread the material nicely to simulate pillows realistic way. I didn't want to care too much and try forming and shaping the clay, because I was planning to cover the sculpted pillows with wet soft paper to simulate the buckram covered pillows. After all, I had no idea how much available time I had, before the material start becoming hard and difficult to handle.
Mesaj Tarihi: 16/09/2009 Saat 02:58
Toilet paper is not only for the obvious purpose but can also be useful for scale modeling. I used ordinary toilet paper, cut it to shape and dress the seat pillows made by air-drying modeling clay, to look more realistic and simulate the buckram covers. Water based white glue for wood, which becomes transparent when it dries, is just the right for the job. So, I opened a 500 grams canister bought for 2€ only, pick a small quantity, add just few drops of water with a syringe into a small metal container to make the right mixture and finally I formed the paper on the pillows with a wet brush, into the desired shape. Because the mixture is enriched with water based glue, the soft toilet paper becomes hard when the water dries.
Mesaj Tarihi: 24/09/2009 Saat 02:06
CHAPTER IV - Right side fuselage construction
As I said at the beginning of this thread, I decide to make the JT-9T building look more interesting and show the model in a way that airframe should look like cutaway side opened and let cockpit detail be easily observed. http://img23.imageshack.us/img23/3663/0005jz.jpg - THIS artistic diagram gave me the idea and that would be a nice opportunity to present my way to do it. To do so, I decide that a solid rock one-piece "negative image" cast of the right side fuselage should be made of plaster first and then build a right side solid replica made of polyester, epoxy or resin. This replica - virtual fuselage, would be the basic line to create a thin right-to-scale fuselage surface.
My local newsagent, usually wraps my newspaper and magazines into a plastic bag, which sometimes I use to collect the trash. This time, I decide to use the plastic bag in a completely different way. I cut free-hand few pieces of plastic, keeping in mind to make them longer & wider than the autogyro scale model dimensions. Using duct tape, I stretched the plastic bag across the airframe, in a way to simulate the full right side and half bottom fuselage surface, trying not to leave any visual wrinkles or marks.
I add some grams of plaster powder and few drops of water with a syringe into a soft rubber cup to make the right mixture. Materials like plaster, start as a dry powder that is mixed with water to form a paste which liberates heat and then hardens. Unlike mortar and cement, plaster remains quite soft after drying and this characteristic make plaster suitable for the job. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time. When the first layer of thinned plaster applied on the plastic bag was dry and hard enough, a second thin layer of plaster was applied to form a basic strong cast. The basic idea, is to let the plaster follow the airframe details, accurate on scale and as thin as possible trying not to apply extra stuff where is no needed.
Found at my local supermarket and got for only 0.5€, the following modeling clay for kids. Some scale modelers, use this material to border camouflage patterns while airbrushing. I pick a piece, mold it into snake alike formation and placed it across the airframe to border the wet plaster flow - yellow color for up and purple color for bottom airframe side.
When I finally enclosed the right half JT-9T scale model into plaster, I left it few hours to get harden in order to be sure that the cast wouldn't break when I would try to remove the scale model from inside. Meanwhile, I took the soft rubber cup which I used to make the plaster mixture, squized it to break the last hardened plaster left inside, so it would be easier for me to clean it afterwards and prepare it for any future mix. That's the reason this soft rubber cup were used for.
As soon as the plaster cast was dry and hardened, I removed the the modeling clay I used for bordering the plaster flow and pull the enclosed JT-9T scale model airframe away, gently. Brushing the area with an old tooth brush, I removed unwanted dust or small broken plaster pieces.
http://www.johnsonsbaby.com/product.do?id=35 - Johnson's baby oil or similar is well know to anybody who have children in house. If you don't have children yet, ask your girlfriend - all girlfriends have a tiny bottle in their cosmetics drawer. If you don't have a girlfriend, close this web page, shut down your PC/laptop and get your feet out of house to meet one! Scale modeling is nice, but feeling a nice female next to you is much better. Continuing with the project, thin layers of vaseline based mixtures can be also used instead of baby oil to apply with a soft brush as a segregative material between the plaster cast and generous quantities of polyester filler applied on the plaster cast.
The specific polyester filler I used, comes with the proper catalyst which provides a solid rock build and approximately 3 to 5 minutes time window to form it into shape. I prefer to use epoxy putty or polyester filler with fiberglass grains for special purposes, because:
    [*]It becomes solid rock within only few minutes or seconds,
    [*]it does not shrink and does not crack after months or years,
    [*]you can pour to any shape that you want but you need to work fast because as soon as you mix it with catalyst cream approx 5%, you have limited time before becoming solid rock,
    [*]you can also put additional layers of epoxy or polyester filler to build up,
    [*]you can sand it, you can drill it, you can use any type of scale modeling glue, any type of primer or enamel / acrylic paint on it with no problem,
    [*]can be purchased at any good crafts store into 250ml, 500ml, 1lt (comes with a tube of catalyst hardener) or bigger canisters and if you can't find it, fear not and try your local decent hardware store and finally...
    [*]it is cheaper than dirt - estimated prices are £3 to £10 depending the canister size, the quality, if contains fiberglass grains for maximum strength etc.
Keep in mind that the chemical reaction after mixing the polyester filler with the catalyst hardener, produces some heat that possibly effect on thin plastic parts, so test it first before try it on your scale model. I don’t think that the produced heat is more than Fahrenheit 110, but better watchout. Remember that epoxy materials are dangerous when breath or shallow and could result skin, eyes or lungs problems or even cancer when used for long period with no precaution measures. Always keep in mind, that a powerful vacuum system to suck away the epoxy dust should be used all time to keep the workbench area clean while sanding or milling epoxy or resin materials. Using an issued breathing mask and a pair of surgery latex gloves to prevent dust contact with lungs and fingers while sanding or milling epoxy, is also an important matter that you should seriously take care of! My recommendation is to also wear an overall working suit (as I do) to keep your clothes dust free while sanding epoxy. Some people might find it too much, but I wouldn't like to bring epoxy dust & grains from my work bench into living room and my beloved.
When the plaster cast used as a "negative image" of the right side fuselage, was filled with a thick layer of polyester filler and had enough time to polymerize and get solid rock, it was sunk into water and stayed wet for few minutes, in order to get moistened, become soft and let the right side fuselage replica made of polyester be removed easily.
…if you still read this, you are a father already or have a girlfriend.
Mesaj Tarihi: 24/09/2009 Saat 02:14
To produce a thin-skinned right side fuselage, the polyester part, must be vacuum formed. That means, that I should build from the beginning a new vacuum chamber box. Vacuum forming is a very simple technique that can produce thin-skinned parts of various forms. I mainly used vacuum forming for producing a variety of components for scale modeling. Basically, it’s all about a box with a connection for your household vacuum cleaner and a series of holes in its top plate and try keeping the box airtight at the seems. The basic idea is to build from scratch or buy one if you find something similar, a wooden box like the one I present. I found the following item (which supposed to be a display box or something, for placing plants, coloured sand & stuff inside and make them look nice as a decoration on the wall) at my local http://www.ikea.com - IKEA . Looking exactly like what I've been searching for and considering the low price (not more that 5€), I preferred to buy it instead of building a new wooden box like this from scratch. As you can see at the following pictures, I removed the glass, applied a generous layer of water based white glue for wood (which becomes transparent when it dries) across the inner joints, to keep them as air tight as practical and be sure that no air could escape from there.
Visiting my local http://www.dexion.com - Dexion store (shelving & racking solutions), I got a 135x85cm http://en.wikipedia.org/wiki/Hardboard - hardboard sheet (more than 1 square meter area) for 8€. This is actually a louvred panel, designed to stand against the wall and accept hooks & spigots for easy storage of everything from belts and hose clips to spools and reels and all kinds of other parts. I cut a piece on the right dimensions and slide it into rail to test the fitting. The 35x25cm top plate has many 4mm wide holes to allow air to be pulled through them. The locations of the holes are not important, and can be also drilled by hand using a hand held drill. Just make sure that they are fairly close together. This top plate should be pretty sturdy to hold the subject being duplicated. I made mine from http://en.wikipedia.org/wiki/Hardboard - hardboard high-density fibreboard plate, but I have seen them made out of aluminum too. The top plate finally was slided into inner rails - otherwise it would be screwed down with flat head wood screws. Be sure to countersink the holes to make the heads flush with the top surface. I also epoxied it down, just to also make it a little more air tight. As long as 1 square meter area http://en.wikipedia.org/wiki/Hardboard - hardboard plate, is more than enough for me and can be used to build more than 5 or 6 vacuum forming device plates, I gave the rest to other fellow modelers who are also interested to build one.
Mesaj Tarihi: 24/09/2009 Saat 22:27
Using the proper Black & Decker saw tool, a 34mm wide hole was drilled through the side of the box to facilitate a vacuum cleaner fitting. Luckily, last week I found a real bargain at the local http://www.mediamarkt.com - Media Markt store and I bought a 1600W brand new Hyundai HVC-6003 vacuum cleaner for 15€ only. I decide to use in this vacuum cleaner into my hobby room and for vacuum forming purposes only. I cut a plastic tube - you may have an old piece of an old tool laying around the house or you can purchase one at a vacuum cleaner shop - and fix it with Bison glue for PVC on the box. Then, I screw a wooden stick into the box's center to prevent any possible hardboard plate bending because of vacuum and finally slide the high-density fibreboard plate through the rails to close the box. I sealed everything with white water based glue for wood. The following pictures show the vacuum chamber box building progress and where you will plug in your household vacuum cleaner.
I also got few wooden picture frames found at the local http://www.ikea.com - IKEA store for only 1€ to 3€ each (depending size) and few metal made spring clamps for 0.5€ each, to use them for steady & tight styrene sheet holding while being heated. Avoid plastic clamps, because they might melt while in the oven. It's also possible to build clamping plates made by aluminum sheet and the two plates are clamped together using screws and wing nuts. Aluminum clamping plates is better but might cost more. For these, you are only limited by the size of the oven you have.
Heat your electric oven to some predetermined level, whatever works and start heating the plastic sheet. I have never tried this with a gas one, so use caution if you do! Once the plastic gets warm, you’ll notice it will droop down. When you think the plastic is soft enough, fire up the vacuum cleaner, take the plastic from the oven and thrown the sheet on the vacuum former. The plastic will nicely form around the moulds. This will take some practice and sometimes a mould tips over or the plastic won’t form properly over the mould (folding around edges). This is also the part where I should warm you that you can burn your fingers - I highly recommend Nomex Aramid flame resistant MilSpec gloves, which I personally use for the job. I buy large plastic styrene 50x30cm sheets for 0.5€ to 1.5€ each (depending width), not the more expensive styrene by Evergreen. When an attempt fails, I usually throw the sheet back in the oven and start again. I’ve included some pictures above, but remember, this description of how to make a vacuum form is only a guide. You can make yours with many variations to suit your own needs and from various materials. Once you have the machine, you can make all kinds of things. You can make a lot of aircraft wings, airframe, panels etc out of a sheet like that. You can make the master molds from basswood, epoxy, polyester etc and the parts you make depend on how accurate the master molds are. The molds must be as accurate and detailed as necessary to achieve the results you are after.
Mesaj Tarihi: 26/09/2009 Saat 07:49
I thought as good idea to try something different this time and I did not use the metal made spring clamps to hold steady & tight the styrene sheet on the wooden frame and experiment with thumbtacks. I placed the frame into the preheated electric oven and I wait few critical seconds watching the plastic start heating. As soon as I noticed that it started drooping down, I removed the frame while wearing http://img525.imageshack.us/img525/4278/nomexgloves.jpg - Nomex Aramid flame resistant MilSpec gloves , to prevent finger burns. While the vacuum cleaner was already switched on, I placed the wooden frame with the pined plastic sheet on the vacuum former plate. The plastic nicely formed around the “virtual” airframe mold... and voila!
Note: If I leave the styrene plastic sheet in the electric oven a few more seconds and the plastic was softened further, I would avoid the shrinkage of the plastic that appears in the lower right corner of the original cast. The fact that the plastic could heat up even more, evidenced by the fact that one or two thumbtacks were pulled. But as long as my point of interest (the whole right side of the fuselage and a bit from the bottom side) formed nicely around the mould, the result fully satisfied me and I didn’t try a new vacuum forming.
Mesaj Tarihi: 27/09/2009 Saat 23:32
Using my X-acto blade, I removed the formed fuselage from the styrene sheet and test fitting on the autogyro scale model airframe. Few drops of CA super glue applied on the right spots across the fuselage joints to make the contact secure, did some light sanding on the fresh produced thin-skinned right side fuselage to eliminate some tiny marks and as you can see at the following pictures, the nearly transparent result is more than realistic to scale and completely satisfies to me.
Mesaj Tarihi: 01/10/2009 Saat 02:22
Remember the previously mentioned wooden picture frames, found at the local http://www.ikea.com - IKEA store for only 1€ each, securing the styrene plastic sheet to be vacuum formed? I kept these thin plexiglass plates, to use them as required. Continuing the cockpit construction, I had to build the rear cockpit cover, so I placed the autogyro model upside down facing a glass surface, I boxed it by placing the thin plexiglass plates around it, securing in place with modeling clay for kids. Then, I removed the scale model carefully, leaving space between these thin plexiglass plates. Wet white plaster mixture, applied into the gap, between the thin plexiglass plates to fill the area. When the first layer of thinned plaster was dry and hard enough, two or three extra layers of white plaster followed to finally build the basic cast. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time.
When the plaster cast was dry and hardened after few hours, I removed the modeling clay for kids and the thin plexiglass plates. The white plaster cast got shaped into proper dimensions but cutting it with saw, filling with tiny quantities of modeling putty added to close minor scratches and pores on white plaster cast surface, dry sanded and finally sprayed overall with gloss shiny coat.
Mesaj Tarihi: 01/10/2009 Saat 02:23
Because I was planning to use smaller wooden frame to secure the styrene plastic sheet (the piece to be vacuum formed is too small, there is no need to spend big plastic card), I had to close the outer holes on the hardboard high-density fibreboard plate. To do so, I cut a plastic bag in shape and covered as required the desired area. I pined a styrene plastic sheet on the wooden frame, insert it into the preheated electric oven as described before and as soon as I noticed that the plastic started drooping down, I removed it on the vacuum former plate, while the vacuum cleaner was already plugged & switched on. The plastic nicely formed around the plaster cast and here is how it looks like.
As long as the piece looked satisfying to me, I removed the formed plastic from the styrene sheet with a new Nr 11 surgical blade on my cutter, test fitting on the scale model and later start adding internal detail.
Mesaj Tarihi: 05/10/2009 Saat 03:32
I placed the rear cockpit’s cover in place and secure it with just one or two drops of CA super glue. Then, using a small pencil, I defined the exact line that the rear cockpit cover should be cut in order to let the inside structure visible. Using the mini Dremel tool, I cut and removed the left half part, in a way to look kind artistic.
Mesaj Tarihi: 05/10/2009 Saat 03:33
My good friend Demitris “Jagdpanther” Pravinos, who is a WWII German tanks specialist scale modeler, sent me about five hundred (!!!) cups he found and looked ideal to use them for mixing colours, modeling putty etc. Few drops of nitrocellulose lacquer thinner and just a little amount of Humbrol modeling putty, were more than enough to prepare a nice liquid mixture to apply on the rear cockpit cover surface, to ensure that little tiny scratches would disappear.
Mesaj Tarihi: 05/10/2009 Saat 03:34
Few hours later, soft sanding and a quick airbrushing with white color to make mistakes, scratches etc become easy to spot, the rear cockpit cover was finally ready.
CHAPTER V - "H" shaped tail construction
The Jukka Tervamäki Engineering JT-9T autogyro designed by Finnish engineer Mr. Jukka Tervamäki, is equipped with a twin "H" shaped tail. To build this, I started by rolling flexible styrene sheet around a plastic tube and forming as required to look like the real JT-9T autogyro right side elevator main wing - only 18 times smaller. Following, using the sandwich method (placing one plastic sheet over another), cutting carefully and working extensively with sandpaper to form into desired size and aerodynamic shape, I manage to build the right side stabilizer wing. As you understand, the left side elevator wing, the stabilizer and rudder, will be stripped in a way to show the airframe aluminum skeleton.
Mesaj Tarihi: 13/10/2009 Saat 01:45
Mesaj Tarihi: 15/10/2009 Saat 04:20
CHAPTER VI - Landing gear system construction
The single seat JT-9 and the tandem seating JT-9T, are available with tricycle landing gear system with a steerable nose wheel or a taildragger version too. For both types, the type of landing gear is based on the placement of the exact CG position, determined after complete weight calculations according the owner/pilot's personal needs. My 1/18 scale model is designed to be equiped with a tricycle landing gear system with a steerable nose wheel. An utility free-spinning tail wheel is also placed, to prevent any accidental damage on tail structure if the autogyro raise nose too high while in ground. Feel free to check the diagrams and images found into my first post of this project, back in page 1.
Using plastic card, sprue, metal wire, resin tires and brakes fit accurately to 1/18 scale diagrams and few unidentified parts found in the sparebox, I build a realistic looking 1/18 scale main landing gear system with absorbers and a steerable nose gear. I stole a nickel plated button from GF's favorite dress (hope she'll never find out where's the missing button or I'm in real trouble), placed it into a plastic tube piece, covered with with transparent plastic card & add some details to simulate the landing light in scale.
Yeah, yeah, yeah... I know! I am a button stealer, but let's admit it! We all prefer less buttons on female dresses.
Mesaj Tarihi: 15/10/2009 Saat 22:50
CHAPTER VII - Canopy construction
The Jukka Tervamäki Engineering JT-9T autogyro canopy is made by bented and cold-formed 3mm polycarbonate sheet. The backwards sliding canopy of the single seat JT-9 version, offers the possibility to taxi and fly slowly with the canopy open, a benefit in a hot climate. The trainer / tandem seating JT-9T, has a side opening one piece canopy. Of course, canopy modifications can be done, according the autogyro owner's personal needs or desires.
I used styrene plastic card to form it as shown into following pictures to give the basic shape of the canopy. Then, a layer of polyester filler applied on the styrene. The specific polyester filler I used, comes with the proper catalyst which provides a solid rock build and approximately 3 to 5 minutes time window to form it into shape. I prefer to use epoxy putty or polyester filler with fiberglass grains for special purposes, because:
Keep in mind that the chemical reaction after mixing the polyester filler with the catalyst hardener, produces some heat that possibly effect on thin plastic parts, so test it first before try it on your scale model. I don’t think that the produced heat is more than Fahrenheit 110, but better watch out. Remember that epoxy materials are dangerous when breath or shallow and could result skin, eyes or lungs problems or even cancer when used for long period with no precaution measures. Always keep in mind, that a powerful vacuum system to suck away the epoxy dust should be used all time to keep the workbench area clean while sanding or milling epoxy or resin materials. Using an issued breathing mask and a pair of surgery latex gloves to prevent dust contact with lungs and fingers while sanding or milling epoxy, is also an important matter that you should seriously take care of! My recommendation is to also wear an overall working suit (as I do) to keep your clothes dust free while sanding epoxy. Some people might find it too much, but I wouldn't like to bring epoxy dust & grains from my work bench into living room and my beloved.
When the basic canopy shape made by styrene sheet, was fully covered by a a thin layer of polyester filler and had enough time to polymerize and get solid rock, I sand it with wet sandpaper to make the cast curved and shiny. To produce a thin-skinned canopy, the polyester part should be vacuum formed. As described into previous chapters, a transparent plastic sheet were pined on a wooden frame, preheated into electric oven and as soon as I noticed that it started drooping down, I vacuum formed it. The clear plastic nicely formed around the canopy cast following the curves & details as planed. Using an X-acto, I removed the formed canopy bubble from the transparent sheet and start adding details, such as canopy's frame. Few drops of cyanoacrylate glue applied on the right spots with great caution. Remember that CA glue does fog the transparent parts and this canopy would not be an exception - that's why I placed some very tiny drops of it, just on few spots.
Mesajý Yazan: Blackbird
Mesaj Tarihi: 16/10/2009 Saat 18:56
It seems more realistic than a Tamiya kit :P
Great work. I congratulate...
Mesajý Yazan: Snake Eye
Mesaj Tarihi: 16/10/2009 Saat 23:43
Συγχαρητήρια. Πολύ όμορφο.
SI VIS PACEM PARA BELLUM
Mesajý Yazan: freeman
Mesaj Tarihi: 17/10/2009 Saat 17:39
Master-Class modelling, respect!!
Özgür.
Mesaj Tarihi: 28/10/2009 Saat 19:54
It’s sad! Obviously, voodoo curses came from the unspeakable dirty Viper snake, got real and the final varnish finishes on the model suffered what the Americans call as http://en.wikipedia.org/wiki/FUBAR - FUBAR - F@cked Up Beyond All Recognition .
In brief words, the color layers popped and “cracked” everywhere on the model’s surface, just before the final touch. For some mysterious reason, the color looked peeled off and an unexpected chipping (I would never succeed this by purpose) appeared! The scale modeling accidents committee is expected to investigate the possible reasons within following days, but unconfirmed sources report "pilot’s error" - OK, I made a rookie’s mistake, while using old colors or coat varnish. Meanwhile, the following actions took place:
    [*]Garlic cloves were hanged across the workbench to keep away evil curses, vampires and “snakes” (or those who claim themselves as “snakes”),
    [*]The scale model were covered with a thick layer of ModelStrip product, locked tightly in a plastic bag and left overnight to let the chemical work.
Mesaj Tarihi: 28/10/2009 Saat 19:57
It’s sad! Obviously, voodoo curses came from the unspeakable dirty Viper snake, get real and the final varnish finishes on the model suffered what the Americans call as http://en.wikipedia.org/wiki/FUBAR - FUBAR - F@cked Up Beyond All Recognition .
CHAPTER VIII - Live After Death
When I started building the model, I did not expect to present the CHAPTER VIII under this title. Bus as all the sad & bad situations in life, it was unexpected and accompanied by great frustration because suddenly I saw months effort to dissolve in only few minutes. The old colours (or bad white spirit solvent) that I used, have led to drying crack. Unfortunately, I ignored all the warning signs such as thick grains left by the white colour in which I primed the scale model before the final painting. Having as target to make this model alive again, just like Iron Maiden Eddie’s http://en.wikipedia.org/wiki/Live_After_Death - Live After Death , I decided to try a full reset – after all, I had nothing to lose! The scale model was already FUBAR.
The following photos show the unsuccessful paint process. The problems appeared marked inside the red circles. Unfortunately, I have no photos of the model while looked completely written-off, because at that time I was not in a mood to take pictures!
ModelStrip, was the first thing came up as the most conventional solution to try paint removing. Following the instructions on the box, a generous stuff applied on the model, wrap it with airtight plastic bag to prevent drying and wait about 15 hours to let the chemical work. Opening the bag next day and checking the results, the colour (or rather the colour layers) were soft and could be removed by rubbing vigorously with an old toothbrush. Unfortunately, using the brush on some very delicate spots (even with careful use), had as result to break / or ruin a couple of plastic pieces. Moreover, the paint could not be removed through narrow points and difficult locations.
At this point and while I’ve already used all the ModelStrip material without being satisfied with the outcome, I decide to change tactics to something more unconventional, such as oven cleaner.
Following the product’s directions as always, I sprayed the model with the material, wrap it with airtight plastic bag to prevent drying and wait about 15 hours to let the chemical work. Testing results next day, the oven cleaner failed no more than ModelStrip. I noticed that the colour could be removed but only when pressure and persistent rubbing with brush and that was prohibitive for some parts of the model. Not having another solution, I approached the most unconventional method and visit a science specialist - my local grocery store!
    - Hey man! I need something really strong to clean up kitchen’s oven?
    - Really strong? Use this!
…and he gives me a dust covered 1lt plastic bottle found in an almost unreachable shelf. Reading the bottle’s label, I found out that it contains http://en.wikipedia.org/wiki/Sodium_hydroxide - sodium hydroxide also known as http://en.wikipedia.org/wiki/Lye - lye (corrosive alkaline substance) or caustic soda and is a caustic metallic base. It is used in many industries, mostly as a strong chemical base with chemical type NaOH.
    - Are you sure that this will work? Are you sure that this is safe to use?
    - Trust me. It’s gonna clean up the kitchen’s oven like a nuclear bomb!
    - How much?
    - 3.50 € . Take it or leave it.
Thinking about a possible failure, I filled a plastic bowl with the milky liquid contained in the bottle and threw all the model pieces inside. As long as the autogyro model was already FUBAR, I had nothing to loose to try. I sealed the bowl with a cover and leave the sodium hydroxide to act for 20-30 minutes while the instructions sets out to wipe the sodium hydroxide chemical liquid after 10 minutes. Opening the plastic bowl’s cover, a nice surprise followed...
The truth is I was delighted! Styrene pieces simply and magically totally striped off the enamel colour layers! Absolutely success, without even apply brush cleaning! Amazing product - incredible grocer! Just because I couldn’t believe it and I wanted to make sure that the colour striped off because of the sodium hydroxide chemical (and not the previous used ModelStrip product or the kitchen oven cleaner), I decide to experiment. I threw in a bowl, already filled with the chemical, a 1/18 scale female figure that I was about to convert for a future project. The specific 1/18 scale female figure, is made by Fast Women brand and can be found by clicking http://www.diecastauto.com/catalog/product_info.php?cPath=46&products_id=912&osCsid=dd354d9db9a25e2c5ce83bdcae7d1321 - HERE ). The results after just 15 minutes in the sodium hydroxide chemical - Perfect! The following pictures, show the "before" and the "after".
Keep in mind that the sodium hydroxide is (and thus should be considered) a strong caustic base. This means that:
    [*]Throughout the impregnation of the model parts into sodium hydroxide, you should take all the necessary protective measures (like mentioned in the warnings on the bottle’s label) and is certainly to use disposable surgical gloves made by latex and breathing mask with appropriate filters to protect against possible fumes.
    [*]The colour stripped plastic parts must be rinsed with soft acid to neutralize the caustic base and produce salt and water. Dunking the colour striped parts in plastic container filled with cooking vinegar and then rinsing with plenty of lukewarm water, plastic is now safe to handle with bare hands.
Mesaj Tarihi: 29/10/2009 Saat 19:03
Under the above "adventure" circumstances and considering that all these years dealing with the scale modeling I've tried many color striping methods (including ModelStrip, kitchen oven cleaners, blue alcohol, brake fluid, nitro laquer disolvent, etc), I think that sodium hydroxide NaOH is the best method so far, for the following reasons:
    [*]Kitchen oven cleaners in spray canisters, can do the job, but they cost 3 - 4 € for a 300ml product in which also includes the propellant gas. On the other hand, the NaOH in liquid form is a pure substance, much less price, taking for 1lt bottle, which equals 3.3+ times more product! Using the liquid form NaOH (which you can fill a plastic bowl), you can sink several plastic pieces, same time!
    [*]The brake fluid may be effective and remove paint, but it is not plastic friendly plastic and is likely to convert the scale model into a blob of molten plastic. It is clearly more expensive and as far it is highly toxic, flammable and hardly to manege, I will not recommended it for scale modeling use.
    [*]Nitric acid laquer disolvent, could be a nice solution for metal figures paint striping, but it is not the best for the plastic. Just like the brake fluid, it does melt and damage plastic parts.
Mesajý Yazan: Toughbeard
Mesaj Tarihi: 09/11/2009 Saat 17:07
Awesome Model. Looking forward to the finished beauty.
I used the same method (thinner with putty) to make the base the paint to stick to before but I had the same cracking happen as well. but only happens with humbrol putty.
I switched to tamiya or gunze base spray and had no problems afterwards. I also use tamiya putty, thinner and tamiya glue mixture as well. works like a charm for corners.
http://www.toughbeard.com">
Mesaj Tarihi: 13/12/2009 Saat 21:20
CHAPTER IX - Applying paint, wash & weather effects
Model parts were washed with liquid soap and warm water to disappear leaving oil traces, fingertips etc and then sprayed with light grey primer.
The first base color layer sprayed with no problem and then a second white color layer applied on specific spots to simulate enlightened areas. Then, using very diluted acrylic color http://www.acrylicosvallejo.com - Vallejo paint, 2-3 extra thin layers were sprayed throughout, until the result become realistic and simulate correctly the enlightened areas.
Mesaj Tarihi: 15/12/2009 Saat 00:16
As soon as the previous layers of acrylic http://www.acrylicosvallejo.com - Vallejo paint and gloss coat varnish dried, I placed small slips of paper between the frame and the sheet of the fuselage, to protect the red colour that was already applied and dried. Next, I masked areas not to be painted using the adhesive Tamiya tape and sprayed with the interior green colour.
Mesaj Tarihi: 21/12/2009 Saat 02:15
After the interior colour dried, the slips of paper and adhesive masking tape removed and minor corrections were made in 1-2 spots with a fine brush. The result was sprayed with gloss varnish, to apply washing on certain points.
Mesaj Tarihi: 18/01/2010 Saat 03:03
The steps are slow, but I prefer steady progress rather than hastily. Unfortunately, the problems are not missed. Although I do not think myself as awkward, after the incident with the (voluntarily flying) autogyro model scaffolding under my sleeve and threw (launched to be precise) on its own initiative, brought about 4 or 5 spin turns and finally abnormal landed about 5 feet away and 3 feet lower, I begin to believe that this model has been seriously voodoo curses. Despite the delicate structure of the fuselage, the use of CA glue and maybe a mirracle, were the main reasons that the model escaped having suffered only a broken landing gear, scratchbuilt again.
After the scale model was masked & sprayed with primary colors as described above, the same methodology followed for the canopy, scratchbuilt by transparent plastic on a vacuum former. After the acrylic paint and mat enamel coat dried, I removed the masking tape and I saw the following:
The masking tape that I had used, had left noticeable marks on the transparent part of the canopy - something that had never done before! Being sure now that this scale model is indeed cursed, I dropped by the local grocery store around the corner from where I returned with few garlic cloves. Not having a similar experience before and fearing that if I try to clean the masking tape glue marks using White Spirit will make the things worse with a huge dull hood, I tried to rub the clear plastic part with alcohol which although more friendly to transparent plastics, had to pass crash test first. Dipping a cotton swab in alcohol and water solution and vigorously rubbing the hood, the masking tape glue marks, finally removed as if it was gum.
With my heart beating on normal levels again and using airbrush, light tones of basic colours and shades of sand sprayed at low pressure to represent the weathering and dusting on LG and the lower part of airframe. After a satisfactory weathering result, the scale model was sprayed with mat enamel coat. I left it 24 hours to dry and the individual parts of the scale model were test assembled (no glue), so that the autogyro model start to look like a united construction and please the eye.
Having now left the last part of the assembly of the individual already dyed parts of the model, such as the rotor blades, the cockpit flight & engine controls, the cables, the seat belts and other necessary details, I begin to hope that perhaps this model might be ready very soon.
Mesaj Tarihi: 20/02/2010 Saat 01:48
Some update pictures after washing / weathering / color fading. Control cables are already installed. Still remain to be added:
    [*]The canopy,
    [*]Both propellers,
    [*]The radio device & GPS,
    [*]The engine control levers,
    [*]The windshield and windscreen wiper,
and also paint some details such as engine cables etc.
Mesaj Tarihi: 30/03/2010 Saat 10:43
Details on the rotor blades and the engine. The rotor blades are made of sterene sheet softened in boiling water to stretch 'n' turn in a way to look realistic. Soft sanding applied on the blade's leading edge to be shaped as it should be. The spinner cone was made of an old 1/48 scale fuel tank tip, found in sparebox.
My little JT-9T princess is posing for the camera...
Mesaj Tarihi: 30/03/2010 Saat 10:44
CHAPTER X - Epilogue
Final details were added. VHF radio with headphones in the cockpit, mobile phone, seat belt buckles, main rotor control bars, cables, etc. To break the monotony of red, a toolbox and a tow added into rear storage area. At last, transparent plastic card were placed to simulate the wind shield glasses and of course the canopy in the open position.
Close-ups of scratchbuild engine. Although initially I plan to represent a brand new bright and shiny engine I discovered that it would not fit the with a faded, dusty and weathered autogyro. That is why I preferred to add much wear, stains from oil and scorched medals at several points and some rust as example in the exhaust.
The controls in this two-seater model autogyro, as with any trainer aircraft, perform the same movements. Feel free to notice the rudder pedals and you will see that the front and the back seat, right rudder pedal is pressed to full FWD possition, bringing the left ruder pedal in full AFT possition . This has resulted in turning the nose wheel to the right and turning the rudder of the tail in such a way as to twist the autogyro to right as defined by the position of the rudder pedals. Also notice that the throttle lever of back seat is attached on a bar connecting to the front seat engine throttle so to move simultaneously. The engine's power transmission is made with a wire, launched by the front seat throttle lever and lead the assembly of the engine. Finally, the control sticks are fallen slightly forward, which of course means that the elevators are set in a similar position. Also notice that the position of controls (stick, rudder pedals and engine throttle) meet the relative position of the elevator and rudder fins, the nose wheel, etc. The front & rear seat rudder pedals perform exactly the same movements as linked to the same wire transmission. If you also check the rudder pedals position, you’ll notice right rudder pedals pressed front end, bringing the left rudder pedals full back. As an effect, the nose wheel turns to the right and rudder fin turns in a way to turn the autogyro to the right as defined by the position of the rudder pedals. In similar manner, both control sticks (which perform exactly the same movements as they are connected to the same bar drive) are positioned slightly forward. This has the effect of elevator fins rotation so as to oblige the autogyro in the descent, as defined by the position of the control sticks. In a similar position the main rotor head is placed as required. As it is known, the autogyros and the helicopters leans to the left or right, elevates nose up or descent nose down, by turning the main rotor blades disc and secondarily to aileron and elevator fins (if present) and turn to left or to right with the rudder fins (autogyros) or tail rotor (helicopters).
Mesajý Yazan: Artt
Mesaj Tarihi: 31/03/2010 Saat 02:15
It looks great!
Mesaj Tarihi: 05/04/2010 Saat 02:37
I’ve been asked about the available space where the rear passenger puts his feet on. From the pictures of the model have been published, and the art images found on the article’s first page, it appears that the rear seat is too close to the back of the front seat - and it is also clear from the blueprints of the real autogyro that it’s not my own assumption or a model building mistake. In real autogyro, rear passenger's feet are not squeezed behind the front passenger seat back, but they are placed left & right of the front seat! To make it more understandable, have a look in following pictures, showing a tandem cockpit seating positions as described:
    [*]The green lines represent the front seat passenger and the position of his feet on the rudder pedals and
    [*]The blue lines represent the rear seat passenger and the position of his feet on the rudder pedals.
Mesaj Tarihi: 10/07/2010 Saat 20:37
CHAPTER XI - Tarmac & grass display base construction
It’s been few months since the JT-9T project was complete. I found nice idea to place it on a display base, simulating an airfield area with concrete ground. The idea was to establish an idea of an abandoned small airfield, now used by general aviation pilots for their weekend excursions. From my local store, I bought a 20x30cm polished wooden picture frame.
I add some grams of plaster powder and few drops of water with a syringe into a soft rubber cup to make the right mixture. Materials like plaster, start as a dry powder that is mixed with water to form a paste which liberates heat and then hardens. Unlike mortar and cement, plaster remains quite soft after drying and this characteristic make plaster suitable for the job. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time. When the first layer of thinned plaster applied on the picture frame, a glass were pushed against the plaster to form a flat basic strong cast. The basic idea, is to produce a totally flat cast and later add some detail or apply extra stuff where is needed.
I left it few hours to get harden in order to be sure that the cast wouldn't break when I would try to cut it into desired shape. Meanwhile, I took the soft rubber cup which I used to make the plaster mixture, squized it to break the last hardened plaster left inside, so it would be easier for me to clean it afterwards and prepare it for any future mix. That's the reason this soft rubber cup were used for.
As soon as the plaster cast got harden, cut into shape and the concrete plaques were lined with a scriber, I used my airbrush to paint it. After the polished wooden frame was covered with masking tape, three different acrylic paint layers were applied on the plaster surface. First, mat black colour covered the area and then a light grey applied with airbrush, spraying in almost zero degree angle, to let the darker areas between the concrete plaques remain naturally dark. The corner was paint with earth tones and as soon as the acrylic colours dried, I tried some drybrushing on selected spots using sand tones.
Mesaj Tarihi: 10/07/2010 Saat 20:39
As for he grass & plants, I used three different ways:
    [*]From my local super market, I got a small wicker broom. If you look closely, you’ll find some very interesting stuff for scale modeling use and dioramas building.
    [*]Found into my garden perimeter, I collect few natural stuff, cut and placed into plastic box for such use.
    [*]From my local hobby shop, I got different colours of static grass, empty them into a plastic box and make a mixture.
Water based white glue for wood, which becomes transparent when it dries, is just the right for the job. So, I opened a 500 grams canister bought for 2€ only, pick a small quantity, add just few drops of water with a syringe into a small metal container to make the right mixture and finally I applied on the desired areas to be filled with grass & plants, using a wet brush. Because the mixture is enriched with water based glue, it is easy to correct possible mistakes.
As soon as the result was OK, I sprayed over with Humbrol enamel mat coat, to seal the paint and grass, so far. I left it overnight and as soon as the enamel mat coat dried, I add very few light & dust effects with chalk dust. Feel free to check final pictures of the JT-9T autogyro placed on the display base.
Mesaj Tarihi: 10/07/2010 Saat 20:42
I also tried some camera shots with black paper background (instead of white) & different light conditions and I was surprised on how the model looks like. From now on, black background and low level lighting only...
PS. A little sparrow bird is now present on tail fin :D
Mesajý Yazan: Baris Can
Mesaj Tarihi: 13/07/2010 Saat 11:28
Resimlerin yüklenme ?eklinde bir sorun oldu?unu dü?ünüyorum. Firefox' da kullanycy ady ve ?ifre isterken, Internet explorer' da açylan kullanycy ady ve ?ifre penceresi sebebiyle sayfa kilitleniyor.
Files installed incorrectly. To see the pictures you want the user name and password.
Mesaj Tarihi: 15/07/2010 Saat 07:42
Orjinalini yazan: Baris Can
Resimlerin yüklenme ?eklinde bir sorun oldu?unu dü?ünüyorum. Firefox' da kullanycy ady ve ?ifre isterken, Internet explorer' da açylan kullanycy ady ve ?ifre penceresi sebebiyle sayfa kilitleniyor. Files installed incorrectly. To see the pictures you want the user name and password.
If you see the following picture, it's not a problem caused by me or the file library which host the pictures. IMHO, I think that this must be a crash caused by modelsitesi forum, because I've never seen anything like this before. Also, keep in mind, that I see the exact same "problem" window, into other threads and articles written by other modelsitesi forum members.
Mesaj Tarihi: 15/07/2010 Saat 11:14
First, followed by the subject like I want you to know.
Page is opened, internet explorer, wants to enter a password, cancel the internet explorer and windows were locked.
Page is opened, firefox wants to enter a password, internet explorer and windows locked when not canceled, but the pictures do not appear.
There is no picture.
I'd advise you to check from another computer. Not notice the problem on your own computer.
Mesajý Yazan: Ares
Mesaj Tarihi: 15/07/2010 Saat 12:24
Same problem here...
Mesaj Tarihi: 15/07/2010 Saat 12:37
OMG! So, nobody can see the uploaded pictures? Let's do a test. Please click http://www.arcforums.com/forums/air/index.php?showtopic=190666 - HERE (it's ARC forum) where the exact same pictures are also uploaded. If you can see the pictures there, we have to admit that the problem is caused because modelsitesi malfunction when receiving images from imagehosting server.
...waiting your news
Mesajý Yazan: Clio172
Mesaj Tarihi: 15/07/2010 Saat 21:27
Pictures've been seen without any problem on ARC forum.
I wish I wouldn't :P .... I'm so jealous.....
Hats off to you Nick...
p.s. I saw your jaw droping f-16 project either.
Mesaj Tarihi: 15/07/2010 Saat 22:11
either I can seen without any problem on ARC forum.
Mesajý Yazan: Nick_Karatzides
Mesaj Tarihi: 14/11/2010 Saat 23:55
CHAPTER XII - Aknowledgments
I would like to express my special thanks to:
    [*]All fellow scale modelers, who have expressed their ideas through this forum and suggested solutions to technical issues encountered during this WIP.
    [*]Mr. George Papadimitriou, owner of http://hobbygallery.gr - Hobby Gallery hobby shop and exclusive distributor for LifeColor & AK Interactive products in Greece, for his kind support and providing all the goodies I asked for - from A to Z.
    [*]My sweetheart wife, who actively participated in the project as an indispensable assistant, offering me relaxing neck massage while working on my bench.
Finally, thank you all for following this thread and I hope you enjoyed reading this article. I’ll meet you soon, on my next scale modeling project.
Regards,
Nick
Sayfayý Yazdýr | Pencereyi Kapat
