Yeni oyuncak
Kategori: Uzaktan Kumandalı Modeller
Forum Adı: Uçaklar
Forum Tanımlaması: İlla kumandalı olacak diye bir dayatma yok, uçsun yeter
URL: www.modelsitesi.com/forum2/forum_posts.asp?TID=3223
Tarih: 26/10/2026 Saat 13:05 Program Versiyonu: Web Wiz Forums 8.04 - http://www.webwizforums.com
Konu: Yeni oyuncak
Mesajı Yazan: Captainairbus
Konu: Yeni oyuncak
Mesaj Tarihi: 18/10/2006 Saat 18:47
Aşağıda detayları ve fotoğrafları olan arkadaşlar su kaçırmışlar galiba....
This 1/9th scale radio-controlled C-17 model was built in the United Kingdom. To date it has about 20 flights. It was built as the centerpiece of a 15 program television series produced in the U.K. For the Home and Leisure satellite TV channel. Built with the aid of three friends, it took 1 year to build and is powered with 4 Jetcat P-120 turbines with a total thrust of 108 lbs. The models weighs over 250 lbs fuelled, and carries 12.5 liters (3.3 US gallons) of 95% kerosene and 5% turbine oil fuel. Other details include 5 Futaba PCM receivers, 16 battery packs (93 cells), 20 Futaba servos, on board air compressor, electro/pneumatic retracts, etc. The four builders are shown in the lower left image above. Colin Straus is at the nose of the aircraft. Wingspan is 20 feet 8 inches, and the top of the fin is 74 inches(6 feet 2 inches) above the ground. Takeoff weight is 264 lbs. The rear cargo doors open and they drop an R/c jeep on a pallet, as well as 2 freefall R/c parachutists. The model also has smoke systems both of the inboard turbines, and uses 2.4 GHz data link to provide real-time data to a laptop computer on the ground while in flight, this data includes airspeed, turbine RPM, EGT, fuel consumption, etc. It is covered in fiberglass and epoxy resin. Built mainly from balsa and ply, with many glass and carbon fiber moldings to reduce weight. This C-17 Globemaster III is one of the largest jet models in the world today! Complete with retractable landing gear and pneumatically operated flaps
------------- ex copilot.
Mesaj Tarihi: 18/10/2006 Saat 18:48
Mesaj Tarihi: 18/10/2006 Saat 19:44
Heyy maşallah........
------------- Hayat bos!!!
Mesajı Yazan: desert-rat
Mesaj Tarihi: 18/10/2006 Saat 21:17
Çılgonlığın sonu yok....
Tek kelimeyle harika.
------------- 4 EVR COOL
Mesaj Tarihi: 18/10/2006 Saat 21:26
Inis yaparken görmek isterdim :)
Bunu gösteri yapacaklari yerlere nasil transfer ediyorlar acaba??
Mesajı Yazan: mk_ozkir
Mesaj Tarihi: 18/10/2006 Saat 21:57
Mesaj Tarihi: 18/10/2006 Saat 22:45
Ingilterenin bir ucundan bir ucuna ucarak gitmiyor herhalde :)
Mesaj Tarihi: 19/10/2006 Saat 00:58
Bu mail abimden banada geldi.hatta koymayı düşünüyordum foruma.azım açık kaldı vallahi.homebuilt bir uçakla aynı boyutta nerdeyse.arkadaki 747 yi de görmüşsünüzdür diye tahmin ediyorum...
Mesajı Yazan: qflyers
Mesaj Tarihi: 19/10/2006 Saat 01:46
Bu da Türkiye'de yapılmış 1/3 ölçek, jet motorlu full scale Platus Porter
Mesaj Tarihi: 19/10/2006 Saat 03:02
Jetten ziyade turboprop motorlu demek istediniz galiba?
Mesajı Yazan: Muratti
Mesaj Tarihi: 19/10/2006 Saat 05:53
Abi her şey iyi hoş da o C17' nin çakıldığını görmek nasıl olur ? Neticede R/C uçakta çakılma çok sık yaşanan hadisedir...
Benim kıytırık Cox motorlu 1:6 P51 çakıldığı vakit kalp krizi geçiriyodum az daha. Bu ekip herhalde en az 2 telefat verir o makina çakılsa...
Vay bee 105 lbs thrust... Ercan şuna full house bi V1 bug set etsene abi... RWY 18, 150/20kts... :))
Bu arada arkadaki LH B747-400 nasıl ??
Mesaj Tarihi: 19/10/2006 Saat 09:44
Aman abi Ercüment abi görmeden kapatın, kitleyin, yok edin başlığı. Zaten C17 yapmaya başlamıştı, büyütüp bunun kadar kağıt model yapıp gelirse ağlarız....
..Efenim??? Poerter??? Anneeee...Ellerinize sağlık.
Mesaj Tarihi: 19/10/2006 Saat 17:59
Nedense R/C uçaklarda scale olanları daha çok ilgimi çekiyor.Ozaman birşeylerin değil bir uçağın uçtuğu hissini yaşıyorum.C-17 gibi devasa bir model zannedersem çoğu R/C modelcinin hayali....
Öte yandan bizdede Pilatus gibi scale R/C modellerinin yapılabilmesi sevindirici bir olay.Emeği geçenleri tebrik ederim.
Mesaj Tarihi: 19/10/2006 Saat 18:48
Yakında 1/2 filan da yapmaya kalkacaklar. töbee töbeee...
Mesaj Tarihi: 19/10/2006 Saat 22:06
Bu da Türkiye'den. Ahmet Atlas, 30 yıllık radyo kontrolcü. Yaptığı tam 5.5 metre kanat açıklığına sahip L-18 Piper Cub ile amacı Asya-Avrupa arasında uçuş yapmaktı. Kadıköy'den havalanacak model, havada başka bir uçağın içinde bulunacak Ahmet Atlas'ın kontrolünde uçacak ve Hezarfen Havaalanı'na inecekti. Proje, sponsor bulunamadığı için hayata geçemedi.
Evet önde Ahmet Bey'in uçağı, arkada da gerçek bir Piper Cub. Sahibi Murat Öztürk. Geçen yıl yaptığımız çekimler sırasında iki Piper Cub beraber uçmuş çok hoş görüntüler ortaya çıkmıştı.
 [/IMG]
Mesaj Tarihi: 19/10/2006 Saat 22:13
Piper Cub'la ilgili Milliyet Gazetesinde çıkan haber...
daha fazla detay için - http://www.milliyet.com.tr/2002/06/02/cumartesi/acum.html
Ahmet Atlas ve uçağı...
 [/IMG]
Mesaj Tarihi: 19/10/2006 Saat 22:18
Bu da iki Piper Cub beraber uçuyor...
 [/IMG]
Mesajı Yazan: Clio172
Mesaj Tarihi: 20/10/2006 Saat 22:17
C-17 harika, TR'de yapılan modellerde emeği geçenleri tebrik ediyorum.
bu amcada abartmış biraz,
Bir de RC B-29 video linki gönderiyorum, altında da C.Yeager amcanın test uçuşları yaptığı X-1'i de (sanırım) mevcut. Video 15MB ancak görülmeye değer.
http://rapidshare.de/files/37434060/B29_RC.wmv - Burada
Saygılar.
Mesaj Tarihi: 21/10/2006 Saat 00:06
Orjinalini yazan: freeman
C-17 değilde 1/20 civarı olduğunu tahmin ettiğim RC A380'in 6.4MB'lık videosunu http://rapidshare.com/files/105011/rc_a380.wmv.html - buradan indirebilirsiniz.
Kolay gelsin
Mesajı Yazan: temelica
Mesaj Tarihi: 21/10/2006 Saat 01:18
süper olmuş Birol abi ...
zaten bizim laz bakkalın tabiriyle
"sen insan değulsun uşağum"
Mesaj Tarihi: 21/10/2006 Saat 21:47
Statik bir model kadar detaylı yapılmış ve bazıları film çekimlerinde kullanılan ölçekli uçak, helikopter, tank vs. modelleri mevcut.
Mesajı Yazan: zuni60
Mesaj Tarihi: 05/07/2007 Saat 20:10
Arkada?lar bunlar inanylmaz modeller, model demeye dilim varmyyor. Aklyma takylan, bu tip veya herhangi RC modellerde trafik açysyndan bi kysytlama varmy? yani ?u irtifadan yukaryda uçamaz ?urda uçamaz burda uçamaz, ?u zaman uçamaz, her uçu? için izin almak falan gerekiyormu. büyüklü?e göre ruhsat falan gerekiyomu...Yani bizde bunlary denetleyen bir takym yasalar kurallar varmy. Biraz muhabbete limon syktym heralde. Ama karde?im ?una baksana... sanyrym bunlar ?u Sukhoi akrobasi uçaklaryndan büyük
------------- XXX
