AFV | |
<< Önceki Sayfa 2 |
Nick_Karatzides
Üye ![]() ![]() Kayıt Tarihi: 06/06/2009 Aktif Durum: Aktif Değil Gönderilenler: 250 |
As for he grass & plants, I used three different ways:
![]() ![]() ![]() Düzenleyen Nick_Karatzides - 20/08/2014 Saat 05:58 |
Nick_Karatzides
Water based white glue for wood, which becomes transparent when it dries, is just the right for the job. So, I opened a 500 grams canister bought for 2€ only, pick a small quantity, add just few drops of water with a syringe into a small metal container to make the right mixture and finally I applied on the desired areas to be filled with grass & plants, using a wet brush. Because the mixture is enriched with water based glue, it is easy to correct possible mistakes.
![]() ![]() ![]() ![]() ![]() ![]() Finally, the FDCV scale model glued on the base with silicon. Final details were added. The antenna masts, the Browning M-2HB 0.50" 12.7x99mm NATO machinegun, some extra dust weathering effect, etc. ![]() ![]() Düzenleyen Nick_Karatzides - 20/08/2014 Saat 05:59 |
Nick_Karatzides
Considering that I am an aircraft scale modeler with no experience on tracked scale models, I have to say that I really enjoyed this FDCV building - no, I am not planing to build another AFV for the following 20-30 years. As for this polyester kit, I must admit it was much easier than expected. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Düzenleyen Nick_Karatzides - 20/08/2014 Saat 06:34 |
Nick_Karatzides
Thank you for following this thread and I hope you enjoyed reading this article. I hope I’ll meet all of you, right after the summer holidays on Amorgos island, where the “Big Blue” Aegean dolphins are living and having fun. Click on the first picture for video.
Regards, Nick ![]() ![]() Düzenleyen Nick_Karatzides - 20/08/2014 Saat 06:33 |
Clio172
Hi,
"img11.imagehosting.gr" server is asking username and password for pictures Nick. Could you please change them as "public" ? Otherwise we can't see these masterclass :) work. Thanks. Keep going. Regards. |
Nick_Karatzides
Orjinalini yazan: Clio172 Pictures are NOT locked or "private". Pictures are public.
Hi, "img11.imagehosting.gr" server is asking username and password for pictures Nick. Could you please change them as "public" ? Otherwise we can't see these masterclass :) work. Thanks. Keep going. As said to another modelsitesi forum member, sometimes, I also see this window (following picture), but I think that the problem is NOT caused by me or the file library which host the pictures. IMHO, I think that this must be a crash caused by modelsitesi forum, because I've already used these pictures on other international forums and never seen anything like this before. Also, keep in mind, that I see the exact same "problem" window, into other threads and articles written by other modelsitesi forum members. Düzenleyen Nick_Karatzides - 20/08/2014 Saat 06:32 |
Nick_Karatzides
I also tried black paper background (instead of white) & different light conditions and I was surprised on how the model looks like. From now on, black background and low level lighting only...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Düzenleyen Nick_Karatzides - 20/08/2014 Saat 06:32 |
<< Önceki Sayfa 2 |
